Engine Swap to SR20DE
I have this 99 sentra wit a GA16. I want to swap it wit a SR20DE, but where can i find a quality JDM used motor? And does anyone know of a complete list of parts that i need for the swap? And what about an engine swap guide... clearly you can tell i am fairly new at this sort of thing. But i feel really confident in doing this...please help!! The car is originally an automatic, and i would like to keep it that way unless it would be easier to change it. But will any of this fit in the body of my sentra...with out have to do any major modifications to the frame of the car??
RE: Engine Swap to SR20DE
Welcome to the forums boards!
Theres a link right at the top of this section- Parts Needed for GA16DE -> SR20DE(T) swap - -SR20DE(T) Motor -SR20DE FWD Transaxle -Driver side axle -Passenger side axle -Crossmember -All SR20 Motor mounts -Front motor mount bracket -Rear motor mount bracket -Transaxle mount -SE-R clutch cable (not needed if still using auto) -SE-R throttle cable -SE-R clutch cable bracket (bolts to transaxle) -SR20DE(T) ECU or G20 ECU (make sure if you're using OBDII or OBDI or use the right ECU) -SR20 clutch kit (throw out bearing, clutch disc, pressure plate) -SE-R wiring harness https://nissanforum.com/m_6996/tm.htm Try ebay or tigerjapanese |
hey wats up?can u tell me if this is possible or not?a 94 altima engine 2.4 in a 93 sentra?
It's possible with the right amount of money... not worth it though imo. Why go with an altima 2.4 when you can go with the sr20?
