-   -   Engine temperature (https://nissanforum.com/forum/nissan-sentra-20/engine-temperature-5406/)
Big Al Feb 4, 2009 10:18 PM
Engine temperature
Woeking on an 04 Sentra. My scanner says the engine is 170 degrees. Sounded low so I pulled the thermostat. When I removed it it was open and the engine was not very hot. So I looked the thermostat up and it's supposed to be 170 degree. Almost every car I see has a 195 degree thermostat. What temperature should a 1.8 L engine run at?
Al
theblacksheep Feb 25, 2009 01:38 AM
within tolerance
The qg18de (1.8L)eng runs at 170 F.
