How To : GA16DE -> SR20DE(T)
Parts Needed for GA16DE -> SR20DE(T) swap -
-SR20DE(T) Motor -SR20DE FWD Transaxle -Driver side axle -Passenger side axle -Crossmember -All SR20 Motor mounts -Front motor mount bracket -Rear motor mount bracket -Transaxle mount -SE-R clutch cable (not needed if still using auto) -SE-R throttle cable -SE-R clutch cable bracket (bolts to transaxle) -SR20DE(T) ECU or G20 ECU (make sure if you're using OBDII or OBDI or use the right ECU) -SR20 clutch kit (throw out bearing, clutch disc, pressure plate) -SE-R wiring harness Here is other useful link(s) for more information- www.ga16forum.com |
RE: How To : GA16DE -> SR20DE(T)
is there any more or less parts i would need to go from a qg18de to a sr20det?
check jspecautosports.com, they have the motors with trans, ECU, etc to get you started
yes sir, the only other things they wont have will be the SR20 MAFS and the motor and trans mounts and im not sure bout some of the cables
Originally Posted by Robin
(Post 9087)
How To GA16DE t SR20DET
I have all four harnesses Rb25det upper and Lower and Ka24de upper and lower If anyone wants to make some money let me know how much do do the harness for my car thanks
thanksss the best web to make more and more money www.wowlife.tk www.freeemoney.tk
i have a 95 nissan 200sx se, their are only a few parts for the GA16DE engine but i dont know if it will make any difference because of the tiny engine.
Thank you So let share with you the latest models of all types of cars is very amazing http://shortlinks.co.uk/1pq7 2010
