-   -   Need HELP!!! (https://nissanforum.com/forum/nissan-sentra-20/need-help-3768/)
RPDSPECV Jun 5, 2007 09:08 PM
Need HELP!!!
I have an 03 spec-v sentra, Ive just replaced my battery, ran well for a few weeks. Came out car wouldnt start. Clutch is good, replaced alt., and starter sounds fine. Car still wont start. Any suggestions???? Please Help!!!
NissanRacer1 Jun 17, 2007 10:42 PM
RE: Need HELP!!!
take off the battery cable on the negetive side for at least 30 and let the computer reset itself,,, make sure both are clean,,, may have a short
HXC_Nismo Jun 19, 2007 01:53 PM
RE: Need HELP!!!
if your car is a manual check your nuetral saftey switch on the clutch pedal assy if thats bad the ecu thinks your trying to start the car in without pushing in the clutch, also since you said youve already replaced the alternator and starter thats where i would look at next.
Burnnout Jun 20, 2007 12:29 PM
RE: Need HELP!!!
Does the car crank ?
Darkmist00 Jul 12, 2007 09:18 AM
RE: Need HELP!!!
I agree with HXC_Nismo, had the same thing happen with my car, that was the problem.
