-   -   Nissan Sentra, Juke, Rogue, Rogue,Tiida Air Filter (https://nissanforum.com/forum/nissan-sentra-20/nissan-sentra-juke-rogue-rogue-tiida-air-filter-39667/)
kasunwck Jan 16, 2023 10:51 AM
PHILTOP Engine Air Filter, EAF048 (CA6900) Replacement for Sentra, Juke, Rogue, Rogue Select, 300ZX, Tiida, Q50, FX35, QX70, Q60, FX37, Q70, Q70L, FX50, M56, Pack
ALL COUNTRY SHIPPING
Price = $11.99
BUY NOW LINK = https://amzn.to/3QIV29S
About this item
  • 98% filtration efficiency: PHILTOP engine air filter is made of high-density and high-breathable heat-sealing cotton, which can filter out various impurities, hair, fines, dust, and flocs, ensure full combustion of fuel, increase mileage per gallon, and optimize engine performance
  • 10 min installation: This engine filter adopts the standard processes of OE parts, and the size precisely suits the housing; it can be directly installed by yourself, without special tools, and no need go to the dealership, which can save you a lot of time and cost
  • Excellent filter paper: The strong and durable filter material can still maintain stable filtration performance without deformation or loss of efficacy, even in unfriendly environments, such as high temperature and negative pressure changes,offering 2X protection for your engine
  • Maximum dust-holding capacity: More folding layers than standard air filters allow maximum dust and debris holding capacity; the reinforced frame is enough solid and durable, effectively improving the seal performance so that it can reduce noise when sealing dirt
  • Warm Tip: The air filter fits for Sentra(2007-2019), Juke(2011-2017), Rogue(2008-2015), 300ZX(1990-1996), Tiida(2007-2015), Q50, FX35, QX70, Q60, FX37, Q70, Q70L, FX50, M56. Please enter your vehicle's year/make/model and then check the fitment
Product Description
https://m.media-amazon.com/images/S/...X970_V1___.jpg
Price = $11.99
https://m.media-amazon.com/images/S/...X300_V1___.jpg
air filter If the following situations happen, you may need to check your engine air filter and replace:
Gas mileage decrease
Cylinder damage
Carbon deposition
https://m.media-amazon.com/images/S/...X970_V1___.jpgStep 1:
• Open the car’s hood, find the air filter housing.
TIP: the air filter usually locates at one of the following places: 1)Left of the Engine; 2)Right of the Engine; 3)Top of the Engine
• Use a screwdriver to loosen the screws, and put them in a proper place
Step 2:
• Open the air filter box cover and take out the old air filter
• Clean inside the air filter box and the cover
• Take out the new PHILTOP air filter, and press along with the PUR rubber of the air filter, to make sure the rubber edge is pressed into the box
Step 3:
• Check step 1 and step 2 , then close the air filter box cove
Compatible Model and Year List:
  • Sentra = 2007-2019
  • Juke = 2011-2017
  • Rogue = 2008-2013
  • Rogue Select = 2014-2015
  • 300ZX = 1990-1996
  • Tiida = 2007-2015
  • Q50 = 2016-2020
  • FX35 = 2009-2012
  • QX70 = 2014-2017
  • Q60 = 2017-2019
  • FX37 = 2013
  • Q70 = 2014-2019
  • Q70L = 2015-2019
  • FX50 = 2009-2013
  • M56 = 2011-2013
Price = $11.99
https://cimg7.ibsrv.net/gimg/nissanf...ee36995a4e.jpg
Price = $11.99
