-   -   is it possible to fix my clutch on my own? (https://nissanforum.com/forum/nissan-sentra-20/possible-fix-my-clutch-my-own-2705/)
nismo327 Oct 27, 2006 08:50 PM
my clutch recently went...i have a 2000 gxe but from what im told theres a certain tool needed to replace it...however nobody seems to know the name of the tool....if anyone knows itd be a hugeeee help to me...thanx alot
etepsnewo Oct 28, 2006 11:20 PM
RE: is it possible to fix my clutch on my own?
Not sure but I have a 1995 200sx and I have see clutch replacement kits that include an alignment tool. Maybe that is what they are talking about. The tool alone is only about $15.
Can you check a repair manual like Hayes. Autoparts stores sell then for under $20. You should have one anyway if you do any work yourself or have others work on your car.
Knowledge is good protection from being ripped off by repair shops.
Good luck with the repairs.
Pete
ridgerunner1965 Oct 31, 2006 10:14 PM
i did mine last winter, just get a book and follow the step by step instructions. the tool you are talking about is just the clutch alinement tool, you dont need it but it is handy. other than usual wrenches and sockets you will need some jackstands or blocks and a small floor jack .if you hustle and dont screw around it can be done in 6 hrs or less.on my sentra the clutch was slipping but the prob was actually the pressure plate being weak.not sure what they are chargeing for a clutch replacement job but if it takes you even up to 2 days ill bet you caN make at least 100-150$ a day dooing it yourself.happy wrenching!!!:)
2dr_sentra Nov 6, 2006 05:49 AM
if you dont have a alignment tool, you CAN eye it up but it maybe a pain to get the tranny back on.
A clutch kit should come with its own alignment tool.
chelle Jun 29, 2007 04:03 AM
it would be fine if you try the clutch replacement.... clutches fail for a variety of reasons like driver abuse, normal system wear, and poor maintenance. looking for highest quality clutch kit would be great.
