Power Window help
Old Jun 9, 2006 | 02:45 AM
anstinnett's Avatar
Default Power Window help
I drive a 1999 Nissan Sentra....my driver side window won't work....have replaced the motor AND switch and it still won't work....after trying to fix it tonight, we blew a fuse for the rear passenger window and it won't roll down...we have narrowed both problems down to a fuse, only problem is....we can't find the fuse....yes, we looked at the box in the dash and the 3 obvious ones under the hood and could only find one generic "power window" fuse....shouldn't there be individual fuses for each window somewhere?? Any suggestions on where to look or what the problem might be?? Any help would be appreciated!!!
Old Jun 12, 2006 | 04:27 AM
Default RE: Power Window help
theres only one power window fuse it sounds to me that you have a short if you keep on blowing fuses, cause if you properly replaced the p/w motor and switch it should work as long as it has a good power and ground so check to make sure you dont have a loose ground or a short on the power side. Do all the other windows operate fine with the master switch on the drivers door?
Old Jun 12, 2006 | 09:36 PM
anstinnett's Avatar
Thanks so much for your reply to my question!! I am not too familiar with this, it's my brother that's working on it, so I will try and make sense and all that good stuff!!
All of the windows work except the driver's window and the passenger's rear....The driver's is the original unworking one, The other one is the one he tried to tap into to check if that made a difference...(when tapped into it the rear, the driver's window did open...)
The fuse that is under the hood has not been blown, that's why we assumed there were individual ones....
Thanks for your input!!!
~ans~
jrcomstock2002
5
Oct 19, 2007 08:01 AM
shipkdc
Nov 25, 2006 12:59 PM
kw168
Nissan 350Z / Fairlady
Nov 24, 2006 02:33 PM
3rdgen
May 5, 2006 06:23 AM
jonathanstan
Oct 23, 2005 08:26 PM
