Radiator fan
its not safe to drive with the fan not working cause if you overheat that engine you could possibly warp the head or even crack the head or block. i would first check the fan relay or fuse and if they are both good then get jumper wires and dissconnect the fan and hook up the jumper wires to the fan and hook it up to a 12volt source or you battery and if the fan comes on then you have a wiring problem if the fan does not come on then the fan is defective and you would need a new one or a good working used one from a junk yard. if this is too complicated take your car to a local shop or a friend that is a mechanic. well hope this helped you
billy_max1
Jan 9, 2006 12:04 AM
