-   -   shifter can not go out of park when engine is on (https://nissanforum.com/forum/nissan-sentra-20/shifter-can-not-go-out-park-when-engine-1570/)
alamorob Mar 25, 2006 11:23 PM
I turn on my 2002 sentra and sometimes the shifter remains locked in park and I have to take it out of park by pressing the manual unlock button, why?
2nrguy May 2, 2006 02:23 AM
RE: shifter can not go out of park when engine is on
if you listen when you press the brake pedal with the car in park you should hear a small click/pop sound from the shifter console, if you dont hear that then your brake switch needs to be adjusted
HXC_Nismo May 10, 2006 08:43 PM
or your brake switch is defective its located under the dash by the upper part of the brake pedal arm
