skline droping boost
i am running a rb20det i have
stock intercooler turbo x s boost controller hks waste gate garret turbo 70 front and a smaller back when i go on boost in any gear the boost goes up and then goes back on vacuum until i change the gear the point were the car is just about to start using the power it cuts back. i have checked for leaks on the intercooler, the piping and found no leaks help me please i dont know if its the waste gate the timing or if the car has a boost sensor that cutting it back |
RE: skline droping boost
What are you using to control the air/fuel mix ? .... I'm no skyline expert... but I'm assuming the air/fuel mix is controlled by the PCM on a stocker.....which means if you added a boost controller and wastegate and bumped up the boost the PCM is seeing that and pulling timing because it's seeing that you are about to overboost.
i got through i was leaking boost on the turbine one of the bolt holes
