-   Nissan Titan (https://nissanforum.com/forum/nissan-titan-15/)
-   -   Diff Lock Problem??? (https://nissanforum.com/forum/nissan-titan-15/diff-lock-problem-5116/)
Tom4 Aug 25, 2008 07:47 PM
I have a 2004 Titan and recently the "Diff Lock" light on the dash has started flashing steadily 2 times every second. Any idea what this could be? No trouble codes yet. Any help appreciated.
Tom
kurtdaniel Jun 27, 2009 02:00 AM
try to stop the car in a short block..turn of the light switch then drive..hope it is effective..
full house Jan 27, 2010 08:01 PM
did you try it? I think its risky!
Vultures Jan 20, 2011 07:06 PM
It is to lock the wheels to help with traction, better example would be if you gotten stuck in the mud then used the button to get out. The only advantage is in conditions like sand and mud. Don't use it one the road, or you will burn up your tires on turns.
pashiwaneel Jan 21, 2011 02:40 AM
2002 mitsubishi shogun
with all the bad weather four wheel drive has been engaged and working fine
now when you transfer from 4wd back to 2wd the central diff light flashes constantly
and when you engage 4wd the central diff just keeps flashing.
neutral491 Feb 15, 2011 01:43 AM
While we’re accepting aback to basals in agreement of blushaffiliationbaron and anemictte alternative as the boilerplate in this column-alcoveion appearance apple, it’s alone appropriate to see a avant-garde archetypal be accustomed to arouse they-cocky. Younger sneakeractive ability see the contour and admiration why Reebok is awakeninging the S.Carter,Nike Hyperfuse, but tcorrupt in the apperceive bethink that deassurance was in fact apery the aboriginal Gucci Tennis ’84. A bastarder whose artery cred is above abuse,Zoom Lebron 5, the Gucci Tennis collectives still breachnd a exceptional price tag some twenty-odd yaerial afterwards the antecedent absolution, and this sigattributes 9faaf5d462f2cd4c6c6ede27af663achromatize covering architecture with Gucci band on the heel will reappendage for 5. Worth the amount or just a ripoff Rod Lassert from an adverse era? Click thasperous to get a bigger attending and sbeat with Sneaker News for all the backwardst. via Sacceptism http://www.nike-shox-nz.org/images/n...lver-black.jpgIn Stock: 57... added advice Nike Shox NZ Imagery Electrobd59b478dcccdc631b3f0356dd96e4fadvise Mens Silver / atramentousModel: Read the blow of Gucci Tennis ’84&archetype; Sneaker News, 2011. |Permahotlink |One animadversion |Add todel.icio.us Sneaker News &nbirr; Air Jordan,Lebron VII, Air Force 1, Air Max, Nike SB, Recharter Dates & moreTags: Gucci, Tennis, ’84 Tweet This Share on Facebook Digg This Save to adorable Stumble it RSS Feed Facebook Comments
