Front bumper for 2006 Xterra
Hello
Does anyone know how to remove the front bumper for the above SUV? I am trying to install a new head lamp but I guess I have to remove the front bumper. It seems hard. If you have a picture, it's even better. Thanks. D |
RE: Front bumper for 2006 Xterra
http://www.courtesyparts.com/betasit...4_577_580.html
That should give you a basic idea... it's real easy. |
You do not have to remove the bumper to replace the headlight bulb.
Open the hood an you will see that you can reach it. for right one better to disconnect the battery and remove it (much easier then whole bumper). Then you disconnect wire (quick connector) and twist the bulb out. Try not to touch a new bulb glass with bare hand, it will reduce bulb's life. |
| All times are GMT -5. The time now is 02:29 AM. |
