-   Nissan Xterra (https://nissanforum.com/forum/nissan-xterra-13/)
-   -   hesitation problems (https://nissanforum.com/forum/nissan-xterra-13/hesitation-problems-3754/)
Alan2258 May 31, 2007 09:55 PM
hesitation problems
I have a 2000 6 cylinder Xterra that was running fine before I went on a short vacation (5 days). When I tried driving the Xterra after the vacation, it started hesitating violently around 40 mph after driving for about 10 - 15 minutes. I put some gas treatment in and it continued to hesitate at all different speeds. I took it to a car repair shop, and after sitting overnight, the mechanic took it on a short ride and it did not hesitate. A diagnostic test found nothing and the mechanic could not get it to hesitate. A high detergent fuel cleaner was added to the gas. I drove the Xterra about 10 miles without a problem. The Xterra sat for a few hours, then I drove back home about 15 miles. The Xterra started hesitating and idling extremely rough for about the last 5 miles and it felt like it was going to stall.
Any ideas?
Thanks,
Alan
justjimmy Jun 1, 2007 07:04 AM
RE: hesitation problems
Sounds like a fuel filter to me.
maxl Jun 5, 2007 09:20 AM
I HAD THIS PROBLEM WITH OTHER CAR.
ONE MINUTE IT WAS RUNNING FINE, NEXT IT IS HESITATING, ALMOST CHOKING AND STALLING.
HAD TO TAKE IT TO MECHANIC SEVERAL TIMES (TUNE-UP, FUEL INJECTOR CLEANING).
HAVE YOU MECHANICCHECKFUEL DESTRIBUTION COIL
Burnnout Jun 13, 2007 11:17 AM
willing to say that its your distributer
fishtrek Aug 31, 2007 03:57 PM
Have themcheck the fuel pump out put before after the filter. Also have the throotle body throat check for dirt & also the butterfly& temperature sensor working properly
