xterra low beams not working
My low beams have stopped working. All other lights work fine. Could it be anything besides the switch ? Thanks for any ideas.
RE: xterra low beams not working
it wouldnt hurt to check the bulbs first then check for voltage with the low beams switch on and see if you get battery voltage 12v and if not then i would check your fuses and if the fuses are good then your swtich is probably bad. if its under warranty take it in to nissan and have it fixed for free
It may be taken on the part of nissan accessories.Your bulb may be defctive and need replacement.try to check it first if it is already need new one.
