DIY Spark Plugs Replacement - CARiD Video Guide
Spark plugs are crucial elements for optimal engine performance. No matter how well you maintain your Nissan truck, they get old and wear out. For maximum fuel economy and peak engine performance, your spark plugs should be replaced every 30 months or 48,000 kilometers. Continuing to drive with worn-out or damaged spark plugs can ultimately cause engine damage. If that's the case, don't hesitate and replace them. We've prepared a new video, showing the whole spark plugs replacement process, with the right parts and tools needed. Our tech expert Greg is back to the shop to guide you step-by-step and give you some helpful recommendations. Keep your engine in working order with CARiD! Fel-Pro® - Intake Manifold Gasket Set https://www.carid.com/images/for-for...o-gasket-1.jpg NGK® - Laser Iridium™ Spark Plug https://www.carid.com/images/ngk/items/93759.jpg |
| All times are GMT -5. The time now is 09:24 AM. |
