High-quality suspension parts by SenSen
The importance of good struts & shock absorbers is difficult to overestimate. Worn shocks and struts could not only affect the ride comfort, but can also cause you to lose control of your vehicle. So if your absorbers started leaking or stopped functioning at all, and the handling characteristics of your Nissan are important to you, these bad boys must be replaced. The Speedy complete strut assembly made by SenSen features premium components only, including Japanese-made NOK seals, chrome hardened piston rod and OE grade coil springs. Durable protection against the harsh weather conditions and long years of perfect work are guaranteed.
Sensen® - Speedy Strut™ Complete Strut Assembly - http://www.carid.com/sensen/speedy-s...-assembly.html SenSen Speedy struts are designed not only to restore a vehicle's original ride, handling and control, but also to significantly improve tire wear conditions. They are relatively easy to install, because the nickel plated hardware is already included in the package. It's highly recommended to replace them in pairs. Don't forget to make the wheel alignment after the installation. Among the products of SenSen company are not only high-quality suspension parts but also combination switches, electronic fuel pumps, door locks, door handles and many others. Check out whole line up of SenSen parts on our web-site: http://www.carid.com/sensen/ |
| All times are GMT -5. The time now is 07:39 AM. |
