Street 'n' Strip This is the secton for all of your track and street racing stories!
Building a V8 Nissan
Old Jan 12, 2006 | 02:13 AM
OutToWinPAHC's Avatar
Default Building a V8 Nissan
I actually sold the 350 and I'm now using a 460 horsepower Chevy Small Block 400, photos coming soon. I am using brand new OEM front springs on KYB AGX adjustable gas shocks. And 1.8" drop springs on the same shocks. OBX Camber Kit, Adjustable Traction Rods, Front and rear Anti-Sway Bars, Energy Suspension Full Busing kit, and a rear upper strut connector. After I pulled the Nissan Motor and Trans I removed all the stuff that was no longer needed. ECU, and 80% of the wires. I had to remove the AC for the room, then I had to cut out the stock battery tray, because I am mounting a battery box in the rear, while I was on the roll I removed all the other mounts and tabs sucks as for the fuel filter, radiator mounts, etc. I then had to think about the cross member, the original plan was to removed the stock cross-member, but after reviewing the frame blue prints I decided to leave it in. I did chop off the raised areas where the engine mounts where and grinded them all down. After that I had to really clean everything under the hood with de greaser. This is where I am at now, this weekend I will be banging in the firewall for the distributor, and I have to modify the transmission area some, I will also have the Transdapt universal transmission mount marked and cut to size, and the transmission Chevy small block engine cross member measured and marked also. Now I am not a welder so I am having a friend weld it for me after the are welded in place I am painting the engine comp with high temperature roll/spray on black bed liner. One this is done it’s a matter of replacing the fuel lines then 240sx has an in tank fuel pump which is going to be used. Fuel injection requires more PSI them a carb so that pump will feed a fuel filter on the firewall, and then a fuel pressure regulator on the wall after that it will be hooked up to the mechanical fuel pump on the motor, then up to the carb (one the motor is in) I’m not too far away from getting the motor in. After that I will have to fine tune the suspension, get my exhaust done 2.5 inch pipe into a 2.5 inch dual inlet flowmaster 50 series, and a single 3 inch outlet. I am not to far away from getting it running and operating. Then I have to fabricate a custom gauge pop using analog autometer gauges, make my cowl hood, hang the wide 50mm fender flares, full body kit, and I have Nissan Skyline R32 taillights. After that I will be painting it thee brownish / maroon from the new BMW's
Kevin
http://www.myspace.com/outtowinpahc
Old Feb 15, 2006 | 01:37 PM
Patrick's Avatar
Administrator
Default RE: Building a V8 Nissan
what kind of vehicle again?
Old Feb 23, 2015 | 01:48 AM
shanewilsonjr's Avatar
Member
Yeh man, We are waiting for some preview pics of your beasty ride !
Mr.HAI
Nissan Of Japan Other Models
Oct 25, 2012 07:32 PM
OutToWinPAHC
9
Jun 30, 2007 02:59 PM
SUNNY1.6
Nov 29, 2006 04:21 AM
focusonmoney
6
Jun 26, 2006 05:48 AM
