2006 Altima 2.5 no crank no start
Old 03-26-2017, 04:41 PM
KennyW64's Avatar
Default 2006 Altima 2.5 no crank no start
Did an engine and trans swap , now it will not crank . Turn the key and the fuel pump kicks in and there is a buzzing sound coming from the trans. Headlights do not dim when I try to start it. Don't know if it matters but I have not installed the axles or put fluid in the trans. What do I check first?
Old 03-27-2017, 06:26 PM
KennyW64's Avatar
Starter relay is good, no power to the small black wire on the starter. changed the neutral safety switch, starter will spin if I put 12 volts directly to it , any ideas ?
hoosierfarmer21
01-15-2018 05:20 PM
KennyW64
03-26-2017 11:54 AM
thefiercewaffle
09-22-2015 09:45 AM
piyyyin
12-24-2008 05:39 PM
hermitape
01-18-2007 03:18 PM
Quick Reply: 2006 Altima 2.5 no crank no start
