instrumen cluster light flickers and gera shifter problem
Old 09-21-2009, 10:21 PM
mfgerms's Avatar
Default instrumen cluster light flickers and gera shifter problem
hey,
im trying to see if i can repair some problems on a 97 altima.
anyone have or know where i can look at wiring diagrams for the car.
the instrument cluster light turns on and off while driving, intermittent . and the gear shift light never comes on. has anyone had that problem. also which fuse is the cluster hooked up to, also the gearshift light.
thanks!
Old 10-04-2009, 07:40 AM
juliarichard34's Avatar
You are suffering with so many problems ,its better to go to a good mechanic and get it solved.I think after that you car will run in good condition.
jbarbaresi
02-20-2009 08:36 PM
vid_ro
01-20-2009 10:18 PM
sabria389
03-27-2008 10:28 PM
MedicMal
02-12-2007 10:42 AM
Quick Reply: instrumen cluster light flickers and gera shifter problem
