2001 Maxima timing cover removal
Old 06-21-2010, 06:26 PM
vectorpro's Avatar
Default 2001 Maxima timing cover removal
I am trying to remove the timing cover on my 2001 Maxima SE. I have removed all the bolts on the cover as well as the alternator and brackets, power steering pump and brackets, I've removed the harmonic balancer and I can't get this thing to budge. I cannot see any bolts not removed and I have checked the pics in my service book and I think I have removed all bolts that should be removed in order to remove cover. I can pry it loose on the top of the cover near the cam sprockets but something in the lower portion of the cover seems to be keeping it in place. I see there are what appear to be two pins one on each side of the cover that protrude slightly. I don't see any way to remove these is this correct? Are there any other bolts hidden that could be keeping this cover from coming off? Any help would be appreciated.
Thanks
Jim
laurita30mx
10-16-2012 11:51 AM
sgt178
05-19-2008 09:01 PM
mmatheny
06-09-2007 08:17 PM
matrix_choices
07-27-2006 12:26 AM
spenny53
07-09-2006 05:09 AM
Quick Reply: 2001 Maxima timing cover removal
