04 HEADLIGHT REMOVAL HELP
There is a flap in the inner fender. Open it and inside there will be a sliding part that hooks on to a post on the back of the light. It should slide down to release it. Then pull like hell and it will pop out.push up to unlock....down to lock when you would hit a bump and gravity did it's thing, you would end up running over your headlight! lol just be careful with your headlight lens because you might scratch something accidentally be ready with a lens repair kit to be safe. ooopps i am so sorry for digging this up because it is just easy to answer it.
