1992 Pathfinder Headlight Problem Hi/Lo Beams
Old Jan 10, 2006 | 12:34 AM
92pathfinder's Avatar
Default 1992 Pathfinder Headlight Problem Hi/Lo Beams
I have a problem with my headlights or at least with the high beams. The low ones work fine, but when you switch on the highs they do not come on (no lights). I thought it might have been the bulbs, but replaced one to see and that did nothing. A local shop said to replace a multi-function switch under/on the steering column. Auto Zone has the switch for about $70, but wanted to check with folks here first before spending that much. The shop said there was no headlight relay that everything was controlled by this multi-function switch. Is that right? Anyone got an answer? Thanks.
Old Jan 19, 2006 | 10:37 PM
Default RE: 1992 Pathfinder Headlight Problem Hi/Lo Beams
i would check your high beam fuse on the fuse block then if that good then change the multi function switch.
luiigmartinez
Apr 25, 2011 06:42 PM
Lynx88
Nissan 300zx
Jul 30, 2007 09:00 PM
kebeaux73
Nissan Xterra
May 17, 2007 11:17 PM
fastfreddie
Mar 28, 2007 01:49 PM
tempestdude
Mar 3, 2006 02:08 AM
