1995 nissan hardbody, replaced motor, out of time
Old 02-01-2012 | 03:36 PM
Billy Sumrall's Avatar
Default 1995 nissan hardbody, replaced motor, out of time
Last aug i bought my truck with a bad engine (ka24e) but a low mileage engine came with it. He had went ahead and replaced the timing chain in it. The pin was set to the first mark on the harmonic balancer not the second ,he pointed it out and said right there is TDC oil pump was already installed , but the distributor came off the old motor, well the guy i paid to swap the motors got the elec plug to the crank angle sensor (on the bottom of distributor) and another one confused , couldnt get fire so he ASSumed the timing was off. didnt get back to TDC and started trying to set the time without being at TDC removed oil pump started messing up. i stopped him, had it towed to my house. nobody is willing to even look at it for less than $800. I decided to give it a try myself. 1st in looking at a wiring diagram i realized the plugs were switched, well it fired i got TDC ( on the #1's compression stroke) removed distributor, dropped oil pump, reinstalled it to so that the rotor button is one #1 , but it trying to crank but doesnt i and when i stop it backfires out the air intake, i dont wanna bend a valve,not sure what to do next any advice would b appreciated thank you for your time
Old 02-01-2012 | 08:54 PM
full house's Avatar
that one need a lot of attention, try to offer them $1000 I'm sure they'll try to fix it... I don't personal know what it should be actual.
specv owner
11-27-2009 05:25 PM
mike1
03-20-2007 04:32 PM
Morkaleb
05-21-2006 12:46 PM
DJfreed
02-27-2006 09:33 PM
