2004 xterra CD/radio CD hung in player
How can I remove this CD, in some older units you had a manual release, that you had to have a paper clip to insert and it released. But I can't find any manual release on this unit, HELP?
cut two thin strips of cardboard( cerial box works perfect) bout as wide as a cd and round a foot long slowly and carefully slip one in below your cd and one above...this will disengage the magnet unit on top of the cd holding it in place...then...your choice...either very slowly slip the cd out...or yank the cardboard peices at the same time...either way at least a small part of the cd should be left sticking out...so grab it and pull it out...and by the way i know you gotta be thinking it...your laser inside will be fine... it sits at least a 1/4 inch blow the cd...hence the thin cardboard...good luck...you should have you cd back soon
Mr.HAI
Nissan Of Japan Other Models
Oct 10, 2012 10:52 AM
beimoting
Apr 17, 2012 10:36 PM
Horseboxpuller
Apr 11, 2012 08:37 AM
