Help!!!
Old Jun 8, 2005 | 10:09 PM
becca's Avatar
Default Help!!!
My 1995 Pathfinder recently started having white smoke coming out of the tailpipe and emitting a strong gas smell when taking off. We thought it might be the fuel sensor but replaced it and did not help. Any suggestions?
Old Jun 9, 2005 | 01:29 AM
Icon's Avatar
Default RE: Help!!!
are you sure its white? that sounds strange because if its fuel, its usually blackish. white smoke usually signifies an antifreeze leak into the cylinders. get a leakdown and a compression test done to see if maybe your headgasket is blown.
Old Jun 9, 2005 | 04:17 PM
Patrick's Avatar
Administrator
Default RE: Help!!!
you can also have someone look to see if there is water in your oil/ oil in your coolant...
Old Jun 9, 2005 | 05:51 PM
Icon's Avatar
Default RE: Help!!!
when my head gasket in my civic was going, i never got the oil/water mix. it just used a little water, and i had to top it off every couple of days. but if the oil is milky white, you have your answer.
RaceY4SlipsTwice
Oct 30, 2019 10:14 AM
