help with timing belt, 98 pathfinder!!!
Old Jun 9, 2005 | 02:04 PM
mannyfresh's Avatar
Default help with timing belt, 98 pathfinder!!!
Hello guys and gals,
Im new to the forums and in desperate need of help. Im doing a timing belt change on a 98 Nissan Pathfinder 3.3 v6 and ran in to a snag. I try to put the new timing belt on as per the Chilton, but it wont go. Seems like the belt is to tight. I can get it around the crank and the left cam but not around the right cam sprocket? And if I do get it around the both cams they move a tiny bit. I reset everything back to the notches. Any help will be greatly appreciated.
Old Jun 9, 2005 | 04:14 PM
Patrick's Avatar
Administrator
Default RE: help with timing belt, 98 pathfinder!!!
hello..i replied on your other post.
Old Jun 9, 2005 | 10:26 PM
mannyfresh's Avatar
I believe so. I matched them side by side and seem to be identical to each other. Does anybody who has replaced theirs know the part #? The oem indicates 133ru25. I purchased an after market belt, is it wise to purchase from a dealer instead?
mmatheny
Jun 9, 2007 08:17 PM
Tarkus697
Dec 20, 2005 05:32 PM
mannyfresh
Dec 18, 2005 07:45 PM
kohla
Sep 26, 2005 12:50 PM
mannyfresh
Jun 10, 2005 04:38 PM
