Low Beam Headlight Bulb Appears “Dim”
Old Mar 13, 2020 | 06:56 PM
dakotadave83's Avatar
Default Low Beam Headlight Bulb Appears “Dim”
2015 Nissan Altima SE...low beam headlights work but appear dim. The low beam bulb cover INSIDE the headlight lens assembly has a milky white look, but the main headlight lens assembly doesn’t. Is there a way to clean the internal low beam bulb lens?
Old Aug 18, 2022 | 07:51 AM
Wlabinho90's Avatar
According to the information in this chart, the low beam headlight bulb is a H11. You can try cleaning the inside of the headlight lens with a cotton swab dipped in rubbing alcohol. If this does not work, you may need to replace the low beam bulb.
Old Sep 4, 2022 | 09:18 AM
Brancasio_chief_senior_mechanic's Avatar
You can try removing it an purchase a product called "Shinex" from most Nissan Dealers. It will fix issue. Price is about $7.99 and it works
nissanOwner
Jul 8, 2009 08:11 PM
DieselDrink
Jan 29, 2008 09:13 PM
nismoboy
Jul 26, 2007 08:21 PM
marts
Nissan Of Japan Other Models
5
Jul 31, 2005 02:40 PM
smenzel
Jul 24, 2005 01:42 AM
