-   -   nissan qx (https://nissanforum.com/forum/general-nissan-tech-9/nissan-qx-522/)
jazz1080 Aug 30, 2005 09:42 PM
nissan qx
hello. I have a nissan qx auto 96.It wont start. The ignition is ok but wont turn over.Please help. All and any hints and tips would be appreciated
mmmmnissan Aug 30, 2005 11:19 PM
RE: nissan qx
what happens when you go to start the car? are there any noises
mmmmnissan Aug 30, 2005 11:27 PM
RE: nissan qx
either way first thing to check would be batt voltage. if you have a dead batt well things dont work on dead batts. then check fuses. if that is good check voltage at the starter when attempting to start car. other than that i think it could be a neutral safty switch. hope that helps
jazz1080 Aug 31, 2005 08:17 AM
RE: nissan qx
What is a neutral safety switch and where would it be located?
Patrick Aug 31, 2005 01:54 PM
RE: nissan qx
and how do you know that the ignition is ok? do you have power in the car?
mmmmnissan Sep 1, 2005 01:41 AM
RE: nissan qx
a neutral safty switch is there to prevent you from starting the car in gear. the car will only turn over and start in neutral or park. i'll look into some more and get back to you on it's location
jazz1080 Sep 2, 2005 10:25 AM
RE: nissan qx
hello mate, the ignition lights on the dashboard light up e.g h/b light, battery light etc.but it wont turn over.also i was wondering if these cars are prone to engine seizure.Thanx
jazz1080 Sep 2, 2005 10:27 AM
RE: nissan qx
Thank you my friend.That would be appreciated.
