P Reg Micra indicator lights problem
Can anyone help please? All of a sudden my indicator lights wont work, occassionally if I keep flicking them on and off they start to work but not for long.
I know its not the fuse as I changed that, the way that its playing up makes me think its a loose wire - but i cant find my manual so not sure where the wires are or what im looking for.
Is there a diagram on-line of the wiring? or does anyone have any advice as to where I look and what I look for?
Thank you
Thank you
are you talking about the backlight for the speedo tach ect that comes on w/ the headlights??? if so then the problem can either be a faulty headlight switch or bad wiring, my recomenation is to buy a cheep test light pull the gauge cluster and see if the backlight is getting power when the headlights are turned on, check the grounds ect ect ect. good luck
brianandchar
Nissan Quest
Oct 12, 2007 07:22 PM
