parking lights arent working, headlights do
Old Mar 5, 2007 | 12:06 AM
thunder's Avatar
Default parking lights arent working, headlights do
i have replaced the light switch on the colum checked fuse, what else can i do? 90 pathfinder 4*4 3.0. any help will be apreciated
Old Mar 5, 2007 | 12:09 AM
thunder's Avatar
Default RE: parking lights arent working, headlights do
i have no running lights but i have headlights, i have replaced headlight swith on the colum, checked fuse, what else is thier? thanks for the help
Old Mar 5, 2007 | 06:28 AM
Solaris's Avatar
Check the actual wiring that attaches to the headlight it may have worn away or broken away either power or earth (chances of this is is slim on both at the same time but you never know). I am unfamiliar with the Pathfinder so I dont know if it is one power line that feeds both right and left so check that the wire has not been severed somewhere closer to the battery cutting off the power completely. You have already replaced the switch so it cannot be that then. Good luck.
Old Mar 9, 2007 | 10:02 PM
paul62462's Avatar
it also may be the relay for the parking lights...most of the nissan family runs from the switch negitve out which then goes toa relay as quiet as you can turn the p/lights on/off & listen for the relay... find it & test it....good luck
paul
79SR280ZX
Feb 3, 2008 02:13 PM
edward1681
Sep 24, 2007 03:06 PM
purple
Nov 4, 2006 01:19 PM
patrick39
11
Jul 1, 2005 06:20 AM
Chalkie
Jun 29, 2005 06:39 PM
