Sentra blower control switch help
I have a 93 sentra, the blower switch started going out , I lost some of the speeds only had 1 and 4, they finally went out also. I replaced the switch but now I only have high speed on the blower position 4. I know the switch was correct it was identical. I checked the relays and swapped it with another known good one but it still only gave me high speed. Can the blower motor itself be bad? I was thinking if the motor was working at all it was ok. Any help is apreciated.
thanks
Harley
thanks
Harley
RE: Sentra blower control switch help
i worked for a non-nissan dealership, and this exact problem happened often...it was the blower motor switch resistor. check with the parts department where you bought the switch, and ask them if ther eis a resistor that can go bad.
Switch Doctor
12-28-2007 10:27 AM
Reesifert
05-03-2007 12:36 AM
gatorgar55
5
12-24-2005 12:45 AM
