Vibration in rear at 65mph+
[IMG][/IMG]
I just bought an 05 Frontier LE 4x4. My problem is that it has a pretty bad vibration in the rear end when it reaches 65mph. I took it in and they balance all four tires but it didn't seem to help, infact it is getting a bit worst. Is there anyone out there that has had this problem...I love my truck but it is very frustrating to me that I paid that much money and possibly purchased a lemon!
if you live or drive on gravel roads occasionally you could possibly have mud along the inside of the wheels or you could have a wheel bearing problem or your drive shaft could be out of balance if I was in your shoes take it do the dealer that you bought it from and tell them to fix it or give you a new frontier cause that something you should not have to put up with when you buy a brand new truck. if they keep on dicking you around take them to court and you definatley have your problem fixed.
Well I think we are on our way to fixing the problem. I believe it is a bad tire, however, the first tire joint that they sent me to disagreed. If you want to read the whole story go to the General Nissan Tech form. There you will get the whole pile of @#$%&.
u hear the vibration inside the car or out because i striped my car and i was hearing vibration it was from the two bars that held my trunk shut so that might be the problem i just used rubber to stop the vibration
Pinkley
Oct 1, 2005 06:07 PM
