fuel pump fuse keeps blowing
Old Oct 5, 2009 | 08:40 PM
240sx _s13 4 LIFE's Avatar
Default fuel pump fuse keeps blowing
hey,
so the situation is my fuel pump fuse keeps blowing on me everytime i turn the key on since i have swapped out a ka24e for a lower mileage one. before the swap it occasionally blew the fuse but now it blows it when the key is turned on. it blows a 10amp right away. and a 15 lasts long enough to start it but then it burns out and dies.
any ideas anyone? i have checked all grounds and they all are tight and look good. and i don't know where else to check
thanks for any advise in advance
Old Oct 19, 2009 | 08:33 PM
full house's Avatar
have you check the engine or the motor?Maybe there are some rusty parts...
Old Oct 30, 2009 | 05:16 AM
D.Amaby's Avatar
rnThis new fuel pump that I have requires a 5 amp fuse. Ive wired a relay so that the pump only gets power if the key is in ignition. Like this:
rn
rnrelay: use a 30amp-40amp relay
rn30 - battery - 20A fuse
rn85 gnd
rn87 to pump
rn86 ig feed make sure its full12v when starter motor is cranking
rn
rnDo I wire in another 5 amp fuse between the 87 and the fuel pump, or can I change that 20 amp to a 5 amp fuse from the battery?rn
Old Nov 4, 2009 | 05:34 PM
counrtyman's Avatar
hey,
so the situation is my fuel pump fuse keeps blowing on me everytime i turn the key on. it blows a 10amp right away any ideas anyone? i have checked all grounds and they all are tight and look good. and i don't know where else to check
Old Nov 10, 2009 | 02:52 PM
glenfoxman's Avatar
i have a pair of 8.1 horizions port motor is fine starboard motor keeps blowing 90 amp fuse on the starter can someone tell me why this would keep happening at 27.00 each i dont really want to go through too many morethanks for any input _______________________________________Website I designed for easy payday loans company.
maggiesmim
May 18, 2015 08:25 AM
shanet1975
Aug 7, 2008 08:21 AM
sunzoon
Nov 3, 2007 08:37 AM
jclayton
Nov 9, 2006 07:08 PM
loomslarge
Sep 22, 2006 08:43 PM
