Auto Gearbox 300zx
Old Jan 4, 2006 | 07:42 PM
Johann's Avatar
Default Auto Gearbox 300zx
Hi I`ve got some gear change problems,whenever I wash the car or drive in the rain the change is very rough or none at all.
Some times it takes for ever to change,some times it changes at 6000rpm from 1st to 2nd, but if i drive hard the gear changes are good.
I`ve changed to a bigger battery as that i thought that the voltage is to low,some one told me to change the gearbox`s valve , which i cant find.
Any advice will be appreciated.
Thank you
Johann(New Zealand)
Old Jan 6, 2006 | 06:48 AM
naz2c's Avatar
Default RE: Auto Gearbox 300zx
Look at throttle position sensor on the driver side of the throttle body . I had this problem also and a friend told me to check it. The screws holding it were loose making the sensor sit in a diagonal angle.I made it parallel to the throttled body and tightened it back up and it shifts like new. I thought the trans was bad and was about to purchase one on ebay when the guy I was buying it from told me to check the TPS.Hope this helps.
nick249
Apr 30, 2006 07:27 PM
jimbob58
Mar 12, 2006 03:03 PM
atc200sx
Dec 30, 2005 04:17 PM
atc200sx
Sep 28, 2005 08:30 PM
Schmeb
Sep 18, 2005 11:06 AM
