t-tops are leaking!!!
Old May 4, 2008 | 07:54 PM
knobelkyle's Avatar
Default t-tops are leaking!!!
my t-tops on my 1990 300zx are leaking! what can i do to stop it?!
Old May 7, 2008 | 02:07 PM
nismo89Z's Avatar
Default RE: t-tops are leaking!!!
check the weatherstrip on the t-tops replace it if it's worn. thats usually the biggest problem with leaky t-tops...clean the surface before replacing it though that way u have an easier time applying the adheasive to the strip.
Old May 7, 2008 | 10:24 PM
knobelkyle's Avatar
where do i get the stripping?
Old May 8, 2008 | 11:10 AM
nismo89Z's Avatar
you can buy it at any autoparts store if they don't have it then you would have to go to the dealer.....its worth it though i had the same problem and all my cd's got messed up because of it. and if it gets into your carpet then its gonna be stinky for a while
Old May 9, 2008 | 10:12 PM
knobelkyle's Avatar
awesome thanks! you wouldnt happen to know how to turn down the idle speed on a 1990 300zx? i tried the screws on the throtle body but all that did was made my pedal sticky... any words of wisedom?
Old May 24, 2008 | 08:10 PM
nismo89Z's Avatar
i know on my models it was on the idle air control valve. i'm not sure where its on the z32 models but if u can locate it that would be your best bet...i don't remember if u screw out orin but give it a try and i'm sure you'll get the result you want.
kelleyj
Apr 24, 2006 01:12 AM
jkon
Apr 20, 2006 01:15 PM
jkon
Useless Posts
Mar 30, 2006 12:48 PM
thorn1998
Nissan 300zx
6
Oct 5, 2005 06:46 PM
topless in Denver
Jul 16, 2005 01:50 PM
