96 Altima engine cuts out at 4k rpm when hot
Old Oct 10, 2006 | 01:50 PM
cluelesscarguy2006's Avatar
Default 96 Altima engine cuts out at 4k rpm when hot
Hello everyone. I own a '96 Altima with 193,000 miles on it. When the engine is cold, everything is fine. Once the engine warms up, if I accelerate, causing the engine to shift down and rev the motor to around 4k rpm, the engine will cut out. Often times the engine will completely shut down. Sometimes the car has to sit for awhile before it starts back up. I hooked up an OBD II scanner to it and got code P0340 "cam position sensor(phase) fault." I replaced the cam position sensor (set me back $57). The car still does the same thing. Any ideas as to what might be causing the problem? Thanks in advance.
Old Jun 26, 2007 | 08:53 AM
eyed's Avatar
Default RE: 96 Altima engine cuts out at 4k rpm when hot
where did you find the replacement sensor?
was it difficult to replace?
sailstransit
Sep 27, 2007 08:52 PM
Durham1
Sep 15, 2007 04:50 PM
stan5677
Aug 20, 2007 09:01 AM
HXC_Nismo
Off Topic
Mar 29, 2007 09:55 PM
ajeyktkly
Aug 2, 2005 07:53 PM
