Help - DTC P0725 and P0335 (Check Engine)
My wifes 2004 Altima 2.5S came up with a Service Engine Soon.
I hooked up with a OBD II reader and came up with:
P0725 - Engine Speed Sensor Circuit Malfunction
and
P0335 - Cranshaft Position Sensor A Circuit Malfunction
The car seems to be running fine with no problems and the codes has not returned yet. Should I still bring the Altima in to the dealer?
and
If your Scan Tool has the ability to "reset" the scan code (fault codes) do that first!
You may have experienced a false reading for some reason.
If the codes stay clear then you have saved $90 or more!
You can take it to the dealer if the codes return again and the car loses efficiency!
The car actually stalled when I came to a stop in a parking lot when I was testing the car... No SES light yet, but it did code the same 2 codes. I'll be taking it to the dealer today, I'm hoping the drivetrain warranty covers this repair (wishful thinking).
i had that problem too all i did was replace the sensor and it runs good.check here it may help solve the problem:
http://www.paulstravelpictures.com/N...ors/index.html
About three days ago my car stalled.. a day after the SE light went on and I could tell that it is getting worst as my 2004 Nissan Altima continues to stall and has trouble starting.
My fiance checked the codes and its P0335 & P0725.. I can not believe we are all having the same problem!!
Tomorrow I am taking my car to the dealership.. I hope they can fix it quickly and not be too expensive.
Hi!..
The weekend that my car got the SES light on was on Labor day weekend which made the Nissan Dealership be closed on Monday (the only day I was available
So, I was talking to a friend and her husband s a mechanic and he researched online, told me to go to Autozone to purchase the part.. $30 something.. and he put it in within an hour and I have had no problem since!!
I wish I remembered the name of the part.. but I would really recommend someone you know who knows about cars to replace it. There is so much info online about this problem and the part. The only thing he said was that he needed a mirror to put the part in.
Anyways, I hope this answers your question..
). So, I was talking to a friend and her husband s a mechanic and he researched online, told me to go to Autozone to purchase the part.. $30 something.. and he put it in within an hour and I have had no problem since!!
These errors are related to the December 2007 recall...
http://www.autobuyguide.com/2005/12-...lls/index.html
Specifically recall #
2005 Nissan ALTIMA Recall ID from NHTSA: 07V527000
This is 100% covered by the dealer and if you have replaced anything make sure to argue for reimbursement since the dealer did not alert you to this. Nothing you replaced will fix the main issue as it is the ECM that needs to be reprogrammed. Hope this helps.
