water temp sensor
Old Jan 15, 2007 | 11:24 AM
Islandboi2009's Avatar
Default water temp sensor
I want some advice before i go and buy this sensor. Does the water temp sensor control or have anything to do with the temp gauge? Mine just sits on cold and never moves. Everything else is the dashboard moves. This is for a 1995 NIssan Altima
Old Jan 15, 2007 | 11:37 AM
Burnnout's Avatar
Default RE: water temp sensor
The temp sensor on the intake manifold doesn't control the gauge... but there is one of the back of the passenger side of the motor that does.
Old Jan 15, 2007 | 02:25 PM
is this how it look burn out? click on the link. if it is i know where it is
http://www.prostreetonline.com/oem/w...r+Temp.+Sensor
Old Jan 15, 2007 | 03:00 PM
Burnnout's Avatar
The picture won't display for me bro... I can tell you that the part number listed is incorrect.... it's not an oem part number... it would only be 10 digits and start with 25080.
Old Jan 15, 2007 | 05:21 PM
Try that link below. It sits on the passenger side, behind/right under the engine vavle pan cover?
http://cgi.ebay.com/ebaymotors/Water...QQcmdZViewItem
Old Jan 15, 2007 | 05:23 PM
also do you know, the time limit on the timing chain? a estimate on how long it normally will last? I've become a mechanic now.
Old Jan 17, 2007 | 12:27 PM
  #7
Burnnout's Avatar
The one from ebay was correct....timing chain usually last 100k or more.... basically needs to be replaced when it starts to make noise.
biznipian
May 25, 2009 08:59 PM
24 brown
Jul 8, 2008 12:54 PM
phootbag
Aug 20, 2007 02:16 PM
Irishluck04
Nissan 300zx
Aug 2, 2006 11:24 PM
jcovault
Oct 20, 2005 09:14 AM
