Starter removal to get tranny out 99 4x4
Old May 25, 2006 | 08:19 AM
alsehendo34's Avatar
Default Starter removal to get tranny out 99 4x4
1. the Nissan shop 99 frontier 4X4 manual 5 speed says to remove the starter in order to remove the tranny. I don't understand why, because it is in front side of were the oil changing tank is pointing in on the drivers side. This is on the other side, (front toward engine side), of the flange were the tranny bolts are and were I assume you make the split to remove the tranny? The starter stickicks out the front on the drivers side toward the front of the car in front of this flange.
Regardless the stupid Nissan shop manual says nothing about how to get the starter out ,it seems to stick into the front of the tranny with no bolts to hold it in and getting @ the cylinoid to remove the wires looks impossible. Please comment / help.
2. I need to remove the shift main control lever and the book again dose not help. Looking down on it you see a square cover over three shifter held down with 4 bolts, maybe 3in by 3in. The shifter goes through a hole in this cover, were a large C clip, (inch 1/2 or so diameter) can be seen. Can you help me with instructions on steps to remove this shifter / shift control arm.
3. It dose not seem to be clear whether the transfer box must be removed it dose say to remove the front drive axle, which is easy, but it looks like the tranny might hit it coming out, (close anyway). It would be a real bear to get out because of the front propeller shaft connecting to it.
4. After getting everything disembled cross suports whats the best way to get @ the top bolts holding the tranny in.
If you think you could help but would need pictures of the bottom of the truck please email me @ alsehendo34@hotmail.com
Any other hints you can think of would be appreciated the manual is not the greatest--it dose a good job @ explaining removal off torsion bars.
Thanks, Steve
Old Jul 26, 2006 | 04:04 AM
blackrain2838's Avatar
Default RE: Starter removal to get tranny out 99 4x4
to remove that starter there are two bolt that attach stright to the transmission.
I8A4RE
Nov 26, 2007 01:24 AM
jnr_chin
Nissan Skyline
10
Apr 16, 2007 12:20 AM
keegach
Oct 3, 2006 07:29 PM
wheelguyz
Useless Posts
Aug 11, 2006 06:11 PM
jugarte
Jul 2, 2005 04:22 PM
