1999 maxima bose radio
Old Dec 30, 2007 | 02:09 PM
JonCam1238's Avatar
Default 1999 maxima bose radio
My Bose CD player works, but it will not light up. So i am not able to see what radio station I am listening to...SOMETIMES the lights will come back but they will fade out shortly. Any idea's on what it maybe or what I should do? Ive checked all the fuses...
Old Dec 30, 2007 | 03:02 PM
maximaa32's Avatar
Default RE: 1999 maxima bose radio
which lights are not ON display or illumination lights ?
how about other lights on dash i mean climate/ac control etc
Old Dec 30, 2007 | 03:05 PM
JonCam1238's Avatar
alll other lights on the dash, cluster etc. are on. the seek, #'s(1,2,3,4,5,6) display where it would show the track..cd play time, or radio staion doesn't light up.
Old Dec 30, 2007 | 03:14 PM
maximaa32's Avatar
as per me there is no electrical wiring problem its internal to Cdplayer. you might need a replacement. or have some electronics repair shop to fix it , or if you can disassemble the cdplayer and check the faceplate connector.there will be two connectors check for any burnout or loose/bent connector
let me know ifyou need any help to disassemble
thanks
Old Dec 30, 2007 | 03:17 PM
maximaa32's Avatar
how about a quick check, try to press the faceplate with your thumbs, one thumb near volume control and other near equilizer control and see if display lightsup
Old Dec 30, 2007 | 04:09 PM
JonCam1238's Avatar
actually...i lied. sorry ahah. everything on the CD player does work. it's only the display where the radio staion or track # appears...and i tried pushing onn it and nothing happened
Old Dec 30, 2007 | 04:50 PM
  #7
maximaa32's Avatar
then you may need to change the connectors or display ,
Old Dec 30, 2007 | 05:33 PM
  #8
JonCam1238's Avatar
alrite. thanks a lot.
jgbluemaxima
Aug 7, 2007 05:09 PM
getophil
Audio/Visual Electronics
Sep 5, 2006 01:40 PM
poplifedc
Dec 1, 2005 05:27 PM
scheibler
Oct 29, 2005 05:36 AM
desilars
Jul 16, 2005 05:07 PM
