2001 MAX Idle Control Air Valve
Talked with my local Nissian Dealer (parts man) Mentioned that the Idle air control valve should be bought OEM and also check engine lite is on, seems Nissian has to set the new Idle valve within spec's... should I just replaced it out and see what happen's ????? I found the part a little cheaper and do the labor myself???
Seems the last owner did not mention to me about it was at the local Nissan dealer(March 07'), in which I went to to investigate the service history (via vin#) to the Service Manger about situation, he had told previous owner was told it possibly is a bad ECU board, I did notice the IACV looked a little new and heavy residue inside the air pleum, so this Friday it goes in Nissan to read deeper codes to this problem, around $90 bucs to see what the step really is???
Having the ECM board replaced on 1-10-08(Thursday) by local Nissan dealership, where is the ECM located, in the kick-panel??? want to mark it for reference, before it goes into service work part is about $775 and computer labor around $250. By the way,how good is the Induction Service Clean charge ($120) going to work out, does it clean out the throttle body pleum, has stated???
Had local Nissan changed out $775 for OEM and tuned to about $225, running good for far Has 12000 mile or 12 month warranty, end of problem(I pray) Starts up by the key . Later to Burnout
dorrin26
Jun 5, 2007 12:08 PM
Reesifert
May 3, 2007 12:36 AM
gatorgar55
5
Dec 24, 2005 12:45 AM
