97 Max horn not working...
Hello ~ I had the unfortunate experience of having someone attempt to steal my 97 Maxima some time ago. They busted up the ignition to the point where the entire steering column had to be replaced. The mechanic, I suspect, didn't really know what he was doing because he kept swapping out salvage steering columns (3 total) and saying that "this one is missing that switch" yadda yadda. Ultimately, I got tired of taking the car back without the problem being solved- even though my insurance had already paid them - and to this day, have a flashing airbag light and a horn that doesn't work.
Recently, I accidentally tripped up the alarm the other day, and the horn DID go off. So, it is only when I press the center of the steering wheel that I get no response. Does this sound like a fairly simple fix, or am I looking at another costly repair if I want to get that taken care of?? I'm a little concerned because I feel 'less than completely safe' when I have no horn and a flashing airbag light, not knowing what would actually happen in an accident situation.
Thank you.
Thank you.
RE: 97 Max horn not working...
Thank you. I assumed the same. Is this something I can do on my own? In other words, how do I get behind the steering wheel pad? Is there prying off involved or is there some sort of release mechanism somewhere? I'm a single woman trying to save money and not get screwed by any more mechanics than I already have! Thanks.
Take battery connector out 30min before playing with the ammo - that deactivates airbag electronics. Clic the link below - links there will give 'all' info needed.
My guess is that those wires remain loose, no airbag...
