air intake issue
Old Aug 24, 2005 | 10:24 AM
nice1a's Avatar
Default air intake issue
i installed an air intake 2 weeks ago - about 2-3 days later the service light came on - when i let off of the gas a stops the idle goes down to 400-500 rpm instead of the 800 it was before. any ideas?? runs a lot better though
Old Aug 24, 2005 | 01:21 PM
Patrick's Avatar
Administrator
Default RE: air intake issue
i had a similar issue...make sure that you have a snug fit, and that no air is "slipping in" anywhere along the intake. i had a point where the intake was allowing unmetered air to enter, and it was causing the SAME problem.
Old Aug 27, 2005 | 02:04 AM
Maxpl74's Avatar
Sounds like your maf went bad[sm=smiley21.gif] ,a common problem on the 5th gen especially with intakes
Old Aug 30, 2005 | 02:43 AM
vrsexxin's Avatar
did you make sure you plug in the maf sensor back, or i hope you didnt drop your maf sensor??? sometimes the ecu doesnt learn right away with more air going in....so i guess if the check engine light does not goes away, try resetting ecu......good luck
Old Nov 10, 2005 | 10:20 PM
RedfoxXx's Avatar
did the ecu list any error codes?
killroy311
Aug 24, 2006 02:20 AM
LEFronty
Apr 29, 2006 11:00 PM
hummerboy6887
Apr 19, 2006 08:21 PM
03Max
Apr 7, 2006 12:59 PM
sancruz904
Apr 1, 2006 05:32 PM
