-   -   Brakes pedal seizing (https://nissanforum.com/forum/nissan-maxima-12/brakes-pedal-seizing-5432/)
dmax Feb 16, 2009 09:47 AM
We have a 2004 Maxima, and twice now in the cold weather the brake pedal has seized. It will not depress, but is stuck in the raised position. You have to press down as hard as you can for a few minutes while the car is running to kick start the brake pedal to work again. What could the problem be?:confused:
Will-I-Am Mar 22, 2009 11:28 PM
Did you ever find the problem and a solution? Our 2004 Maxima is doing the same thing.
Thanks
WIA
kibatheloanwolf Mar 24, 2009 09:01 AM
possible water in the lines do a flush of you entire brake system just in case
