car won't start facing up hill
Old Sep 22, 2006 | 01:22 PM
maxima97's Avatar
Default car won't start facing up hill
1st post any help would be appreciated. I have a 97 maxima se that won't start if it is facin up hill, no problems starting when facing down hill. I tried replacing the ignition switch but still had the problem. So I put the old switch back in. Then I tried replaced the inhibitor switch and I am still having the problem. Sometimes when I am on level ground it will not start either unless I push the car forward when it is in park and turn the key. I had a mechanic look at it and he was the one that replaced the inhibitor switch. He is not sure what the problem is so I am looking for some additional help. When I mean won't start the starter does not turnover. PLEASE HELP!!!
Old Oct 4, 2006 | 04:19 PM
KA20DET's Avatar
Default RE: car won't start facing up hill
fill up the gas tank
Old Oct 5, 2006 | 03:08 AM
reiska's Avatar
When u push, engine which is on rubber bushings, moves. This affects all wires & connectors between chassis/engine.
I suggest you clean and/or swap positive batt-solenoid & solenoid ctrl And gnd wire/terminals. If that doesnt hlp, its starter/solenoid service time.
...gnd wire typically rots away. Take batt tray out first:
http://www.cardomain.com/ride/748507/10 & http://www.cardomain.com/ride/748507/5
flatlanderinvt
Nov 14, 2006 05:28 PM
Chris J
Oct 19, 2006 11:21 PM
rm777
Nissan Quest
Dec 3, 2005 04:28 PM
wmartin
Nov 25, 2005 06:12 PM
RichG
Sep 26, 2005 09:42 PM
