94 Quest won't start
Old Jul 1, 2005 | 03:14 PM
rm777's Avatar
Default 94 Quest won't start
No click, no nothing.
Battery measures 12.7V.
Starter motor tested good at auto parts store.
Any and all suggestions appreciated.
Old Nov 1, 2005 | 02:23 PM
N3FOL's Avatar
Default RE: 94 Quest won't start
ORIGINAL: rm777
Looks like your starter is not getting any juice from the battery. Re-check you cables again and clean the terminals. Is there anything else that you disconnected? If there is, make sure to re-connect them. Good Luck.
Old Dec 3, 2005 | 04:28 PM
FireDoc's Avatar
Possibly a solenoid. If all your connections are good it is time to look at the parts that would activate the starters operation. Ignition switch, solenoid, relays,etc. Unfortunately I am totally unfamiliar with your vehicle. What year is it? If it is old enough you may be able to do the old screwdriver bypass(bridging the posts on the solenoid) Do your accessories come on when you turn the key to on position?
timm747
May 20, 2006 01:21 AM
chris g
Mar 3, 2006 02:27 AM
clroyer
Nissan 300zx
Dec 24, 2005 01:09 AM
wmartin
Nov 25, 2005 06:12 PM
RichG
Sep 26, 2005 09:42 PM
