Idle Air Control Valve 2001 Maxima GLE
Discussed recently this problem, also discovered this part is very expensive (OEM $280.00) & Auto Zone about $220.00, I did take apart the (idle air control valve) curious to see it function, also noticed past the throttle-body assemby( I guess it is called the air intake pleum, is heavy with residue build-up, I cleaned out what I could) put all parts back to same) also curious the in-out part of the idle air control valve has fluid present(anti-freeze???) is this normal, or I have additional problems to solve, inaddition to paying for new IACV, seems I made the problem worst at start-up(check engine lite is on & rev's are up/down on its own) car does run well after warm-up period, also this 3.0 Maxima is not to good on gas mileage, since I have owned it??? hopefully it is related to this Idle air control valve issue, down on my luck Thanks for any feedback to this issue
Reesifert
May 3, 2007 12:36 AM
gatorgar55
5
Dec 24, 2005 12:45 AM
