knock sensor
Old Feb 21, 2007 | 01:15 AM
rickie d's Avatar
Default knock sensor
does a 1987 maxima have a knock sensor an if so where is it,and what effact does it have on performance.
thanks
Old Feb 21, 2007 | 03:20 AM
reiska's Avatar
Default RE: knock sensor
My guess is that it has. When bad, it reduces ign advance causing significant fuel consumption, pwr loss. It can be bypassed with5c resistor, read page9 how/why/what, & possibly youll find 'where' via top left 'Favorite Links' first clic link below.
Old Feb 21, 2007 | 11:58 AM
Burnnout's Avatar
87 Maxima doesn't have a knock sensor.
Old Feb 21, 2007 | 10:55 PM
rickie d's Avatar
burnout just found out today that you are correct my 87 maxima does not have that sensor. but i am having a problem that i cant seem to figure out i have replaced plugs ngk,cap rotorstill not getting the power that i think this engine can produce it doesn't idle very smoooth and it surges some what while driving. any help would be appreciated.
thanks
Old Feb 22, 2007 | 10:42 AM
Burnnout's Avatar
Try some injector cleaner.... the ones you dump in your tank work pretty nicely...... at lot of the older car's are getting clogged injectors since they switched up the gas.
Old Feb 22, 2007 | 09:33 PM
rickie d's Avatar
put in some seafome a weak ago is this good product to use or what do you recommend,an how many tank fulls do you Guss it will take.
thanks
Old Feb 24, 2007 | 10:20 AM
  #7
Burnnout's Avatar
Normally if it doesn't help on your first tank, it's not going to help at all.....never used seafome.... we use a product call power charge from wynns..... it works great.
Old Feb 25, 2007 | 12:01 PM
  #8
rickie d's Avatar
thanks
biznipian
May 25, 2009 08:59 PM
kickdrumz
Aug 30, 2007 01:45 PM
Vitico
Mar 2, 2007 08:53 PM
saltykayak
Oct 16, 2006 02:12 AM
Rub8322
Aug 11, 2006 12:42 AM
