Need help w/ hose 95 MAXIMA
Old May 13, 2005 | 03:33 PM
Tony Nitra's Avatar
Default Need help w/ hose 95 MAXIMA
I need help identifying the hose shown on the picture. It’s a small (about 10mm) hose turning up near the valve cover, rear left (driver side) corner. I found the upper end of this hose disconnected. Engine seems to run OK with hose disconnected, but I need to know where it goes and connect it before I take the California smog test.
[IMG]local://upfiles/83/EC5613E2956C4CDF92E4314F3EA74A1D.jpg[/IMG]
Old May 13, 2005 | 07:27 PM
ZyaLater's Avatar
Default RE: Need help w/ hose 95 MAXIMA
are you sure it iZnt a crankcase breather hoZe?
Old May 13, 2005 | 07:49 PM
Patrick's Avatar
Administrator
do you see anything up top that it should be hooked up to? i would also think that it is a vent tube. with the car running, does the hose spray anything out at all, or create any suction??
Old May 16, 2005 | 01:23 PM
ZyaLater's Avatar
hmmm, maybe he fixed it?
Old May 16, 2005 | 05:16 PM
Tony Nitra's Avatar
It was probably a vent. I passed the test.
Thank you guys.
Tony
Old May 16, 2005 | 06:57 PM
ZyaLater's Avatar
good! glad everything worked out for you!
pacuk01
Apr 29, 2015 11:22 AM
pcumming
Nov 1, 2006 03:42 AM
alikk23
Jul 9, 2006 04:22 AM
frlac40
Dec 6, 2005 06:30 AM
