1996 Pathfinder Timing Belt Help
Old Sep 26, 2005 | 12:50 PM
kohla's Avatar
Default 1996 Pathfinder Timing Belt Help
I am replacing the oil pump on a 1996 Pathfinder. I am in the process of putting it back together. I think I put the crank at TDC on the harmonic balancer (aligned the pointer to the first mark on the left) and verified that the marks on the cams lined up with the marks on the rear cover. I want to verify that everything is going back together correctly. My question is: What is the dot on the crank sprocket supposed to line up with? The manual I have shows a mark on the oil pump housing. Neither the old pump nor the new pump have a mark on them.
Thanks,
Andrew
mmatheny
Jun 9, 2007 08:17 PM
Tarkus697
Dec 20, 2005 05:32 PM
mannyfresh
Dec 18, 2005 07:45 PM
mannyfresh
Jun 10, 2005 04:38 PM
mannyfresh
Jun 9, 2005 10:26 PM
